12-24-2023 05:31 PM - last edited on 12-24-2023 08:21 PM by computergeek541
I need a CS agent to port out from public Mobile, I am not receiving the sms verification to port out my number.
12-24-2023 05:37 PM
You have submitted your port request with your new provider? are you just not getting the porting authorization text?
Make sure your PM account is active and you can still receive incoming calls and text
Then call your new provider and ask them to re-trigger the porting request.
Wait another hour or two and you should receive that
If still not receive the text from PM asking you to approve the porting, please open ticket with PM support using this direct message
Make sure that you respond to this text within 90 minutes. If you do not receive this SMS or you do not respond within the 90 minute window, make up to 4 additional attempts to send it. If you are still experiencing any difficulties, reach out to a Customer Support Agent
(Ref: https://www.publicmobile.ca/en/on/get-help/articles/porting-out )
12-24-2023 05:33 PM - edited 12-24-2023 05:35 PM
use this link to message Customer Support to help you port away...
added port info....https://www.publicmobile.ca/en/bc/get-help/articles/porting-out
