06-09-2022 02:03 AM
06-09-2022 06:47 AM
Let the Customer Support Agents (CSA) know about this as well, submit a ticket here – to be directly connected to the Fraud Management Customer Support Agent (CSA) team who may be able to restore your original SIM card.
Other helpful information to review for your situation :
https://www.publicmobile.ca/en/bc/get-help/articles/sim-swap-fraud
https://productioncommunity.publicmobile.ca/t5/Announcements/SIM-Swap-Fraud/m-p/650969
06-09-2022 05:08 AM
@AKOTTAWA So, are you not able to access your Self Serve My Account?
For your PM service, is your SIM not working now because someone hacked into your My Account and changed the SIM?
If that is the case, sound like you have a bigger problem then just your PM service. You should check your other email services as well as Banking service. They might have access to those as well. Contact all of those and change the passwords immediately. Please use different passwords for different accounts. Not a single one for all
For PM, you can contact PM Support and put the service on Lost/Stolen first and work with them to get the access back.
Message them here:
06-09-2022 03:22 AM
I am really surprised they got into your iPhone. Security is normally good on a newer iPhone.
I would also you bring your 13 into an Apple Genius Store and see what an Apple staff can do for you
06-09-2022 03:20 AM
Can you bring it in to an apple store?
06-09-2022 03:00 AM
I have chabnged the password the malware is in my iphone 13pro and even resetting it to factory will not get rid of it...... They haver access to text message confirmatioin codes before i even recieve them
06-09-2022 02:17 AM
If you can login to all your accounts like financials, emails, here then obviously change the passwords. Now.
Do you still have services with your phone?
06-09-2022 02:06 AM
they also have access to my email address associated with this account
06-09-2022 02:05 AM
What makes you think this? What is happening?
