MMS
NoshinShoae
Hello
I used to be able to send and receive MMS with Telus, since I switched to Public mobile unable to send/receive MMS.
Could you help me please?
Thank you
TanyaMR
Thank you! This saved me. I have a OnePlus and was resigned to needing a new phone or new network, but this did it!
@saulivar5 do you have a OnePlus?
If you do,  there might be a bit more work than simply updating.  Many confirmed that you need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces.  Remember to save the new APN and then reboot the phone before you try
APN:  SP.MB.COM
     (All cap is needed )
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
             (or try:  http://aliasredirect.net/proxy/mmsc)
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
saulivar5
I tried all kinds of settings, none of them work. Here's what I currently have and it's not working:
Here's my configuration:
APN: sp.mb.com
MMS port: 8799
MCC: 302
MNC: 220
APN type: default,ia,mms,supl,fota,hipri
APN protocol: IPv4
hi @NoshinShoae
what phone do you have?
update the APN settings and test again
What phone do you have?
try update the APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
slusagm
MMS is included and would work.   Make sure mobile data is turned on
Chalupa_Batman
@NoshinShoae wrote:
Hello
Thank you
Hello @NoshinShoae
First, go into your network settings and reset them. Then reboot. Then, go back into your network settings and turn off automatic. Then pick Public Mobile and then reboot again. THIS should solve the problem as it did for my buddy. Side note, make sure your data is turned on as MMS requires data.
