03-08-2024
04:23 PM
03-08-2024
04:26 PM
computergeek541
Older phone ASUS Zenfone 4. Was working fine then since two weeks ago I can longer send or receive pictures or long messages using my messaging app. I've tried Google Messages and QKSMS but neither work. What's going on?
06-06-2024 07:11 AM
Hi @hTideGnow
Yeah - I've tried that, stuck on figuring out how to make the APN settings stick; after reboot my fone (Blackberry Key2) reverts to the original settings. I cannot delete or edit the original settings; had to create a new APN setting, but like I said, after every reboot, the phone goes back to the original. Thinking might need the SIM card replaced.
06-05-2024 03:20 PM
hi @Jakubot2000
what phone you have? your phone might need APN update
But try to update your APN, make sure you update these fields
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
06-05-2024 03:17 PM
LOL, not helpful - common problem (I am having the same issue - using the native app)
03-08-2024 04:38 PM
Use only native texting app. All 3rd party apps are mostly bad written junk.
