MMS messaging
WarrenAnderson
Why is it that when i go to APN settings the service provider of public mobile is shaded out so i can not change any settings? My mms messaging is not working?
2 REPLIES 2
fixin1
@WarrenAnderson - Did you just activate? MMS & SMS are having issues for new activations.
Maybe try a full network reset on your phone * You will lose all saved Wi-Fi networks and BlueTooth connections! *
If nothing please contact CS_Agent to see what they can do:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
@WarrenAnderson  Try resetting network settings see if the helps to update the APN for you
