MC was not charged, phone plan deactivated, cannot set up auto payment , Rewards Reduced
nilimasaha
I updated auto payment with a new MC 2 months ago and it charged me last two months but this month it did not and instead deactivated my phone plan. I had to reactivate by manual payment.
Plus my Refer-a-Friend Reward has been reduced from $8 to $3.
I talked with bank for Master Card. They told the card has no problem instead Public Mobile did not try to pull money at all.
I tried to set up Auto Payment with my MC again through my Public Mobile account but it is saying that they cannot verify my MC which is ridiculous. It took money from the same MC in the last two months and now they are saying that they cannot verify.
I really appreciate if Public Mobile fix this Auto Payment Set Up problem and adjust the reward amounts with the future payment.
geopublic
@nilimasaha  Unfortunately as you found out AutoPay  will fail once in a while. When that happens and there is nothing wrong with your credit card you have to manually make payment to re-activate your account.
In most cases the verify error occurs because of how the PM system parses the CC address info (not your profile address). If you're having trouble registering or updating your credit card, here are a few tips you can try:
    1. Make sure the billing information you entered is exactly as shown on your credit card statement.
    2. Use uppercase only
    3. Do not include any apartment/condo/suite numbers, and do not enter any special characters or abbreviations in the address line.
If it's still a problem then there is the possibility that a security lock was triggered on your account and needs to be cleared by submitting a ticket to the Moderator Team before you can register you card again.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking  here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link  sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Hope this helps!
@mpcdesign impressed wow, so thorough covering all the OP issues. Just wanted to say beyond a bravo. GREAT WORK!
@nilimasaha once the autopay credit card is attached. You may reactivate a suspended account online or by calling 611.
Via your account online
1. If you have already registered, or will first register, a credit card, go to step 2. OR deposit a voucher for at least your plan cost and go to step 3.
2. Go to the payment tab, select single payment and  amount due.
3. Select the reactivate account button.
4. Restart your phone.
or Using 611 to make your payment: ( you need your 4 digit pin to buy an add on)
1. press 1 to make payment
2. press 2 credit card ( or 1 voucher)
3. press 1 amount due.
Welcome to the community.  Stay safe.
mpcdesign
@nilimasaha,
Refer a friend from $8 to $3 would mean, you referred 8 people. By any chance 5 people left, which means you now only have 3 referrals? If you truly think there is no way these people are still with Public Mobile, then yes, fill out a ticket.
In theory, to contact a moderator you need to click on the ? on the lower right-hand corner.
Chat with SIMon with your issue, so it can create a support ticket for the moderators for you. Click here for the direct link to the SIMon too if you prefer too. Once you think it understands the issue, type submits a ticket. Expect a moderator to get back to you up to 48 hours.
Second issue: Credit card issue. Yes, I was just telling someone last night, that I thought Autopay was flaky, as it was for me. What got me, was I had changed the address on my account, which didn't reflect the correct address for the credit card. Both addresses needs to be the same.
When you in to your profile in
your self-serve account, make sure you enter the correct address. If you live in-suite, condo, loft, unit or apartment, enter the address as to how Canada Post would address it 555-555 My Street.
Once you have done that, go back in your Overview, click on the third tab, that says Payment. secondly, click on AutoPay to register your credit card.
Enter the fields of your as per the form. Be advised, where there is spot for the apartment number, leave this blank, and put it as part of the street address. For example, if I live in an apartment, suite, loft, unit, I would type in the field of street address as:
555-5555 Anywhere Ave
Once you submit the form, it will take a few seconds, don’t close the window until you get confirmation such as this one:
Once you get this message, you re now signed up for Autopay.
Once you have done that, follow up with the moderators, and state the issue and what you have done, ie, made sure the profile address is the same as the credit card information. Because you'll eventually have to do this anyways! And explain that you lost your autopay rewards, and the refer a friend rewards too. Be polite, and courteous, **bleep** happens.
Hope this helps a bit!
JoyLuck
@nilimasaha
Clear your browser cache/history/cookies. Close browser and open a new browser in incognito/private mode. Also, you can try a different browser.
Enter the credit card address Exactly as it appears on your statement.
Leave the apartment field blank. If needed enter your apartment number in the street address field.
Enter your postal code without spaces unless there is a space on the credit card statement then enter the first 5 digits only with the space.
Note: The credit card will get locked after a few failed attempts. You will then have to contact a moderator for assistance to have it unlocked.
As well, here is a very recent thread on the refer  a friend reward lost credits:
https://productioncommunity.publicmobile.ca/t5/Rewards/15-Credit-lost-in-one-month/td-p/542520
If you need to contact a moderator do the following:
Please use the chatbot SIMon to help you solve your issue. If SIMon cannot solve your issue then you have the option to contact a moderator.
Step 1: Choose the ? button at the right bottom corner of this page or choose “Get Help” at the top of the page and then choose the “Chat with SIMon” button.
Step 2: Tell SIMon what the issue is and see if he can find a solution for you.
Step 3: If Simon cannot find a solution then type in “moderator” to connect to a Public Mobile customer service representative.
Step 4: Simon will present you with two choices. Choose “Account-specific question”.
Step 5: Then choose “No, I want a human”.
Step 6: Create your ticket.
Check the sent folder to make sure your ticket was sent (envelope icon, top right) and the inbox for a reply from the moderators.
gpixel
@nilimasaha
I suggest speaking to customer support by clicking this link below:
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
Moderators are available from Monday to Friday from 8AM to Midnight EST and from Saturday and Sunday from 8AM to 10PM PM EST
