07-01-2020 11:03 AM - edited 01-05-2022 11:55 AM
Hi,Could any one please conform "Samsung SGH- A847R" is not compatible with the network.The phone name isn't in the mobile list and it's frequency doesn't match.Thanks.
Phones
07-01-2020 11:18 AM - edited 07-01-2020 12:05 PM
@RezaT it a 3g phone, has no LTE capability. It will work for talking, texting and mms texting. And you will get access to data where there are 3g bands available. Welcome to the community. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
07-01-2020 11:12 AM
There's this link on the forums of the rugby 2 from last year. Someone trying to set up APN settings for the phone so I guess it works.
07-01-2020 11:12 AM
@RezaT you can check if it is compatible by checking the ime# at this website.
To get your IME# dial *#06#
https://mobility.telus.com/en/ON/phones-and-devices/devicecompatibility.shtml
07-01-2020 11:09 AM
It should be compatible based on these specs.
https://m.gsmarena.com/samsung_a847_rugby_ii-3355.php
Make sure it is unlocked.
