Loyalty points
afralick
Have been a PM member for several years but only getting $1 off per month identified as “loyalty”. Is there an issue here?
14 REPLIES 14
afralick
Thanks! Looks like it is only 19 months (based on “pre-authorized payments” to date indicating 38).
@afralick
Could you show us a screenshot?
If it shows 6 (with PM for 6 years) so you are with PM since 2016?
@afralick it shows $6, theb according to that this is only around you 18 months here.  You joined around Jan/Feb 2021???
or you have suspended for couple months during this time??
Your start date (anniversary day and month anyway) is also shown in discover points as I mentioned earlier. You should have a rough idea of what year you started.
Adding, then that would suggest you've been here about a year and a half.
afralick
Loyalty pays shows 6 but that is cumulative to date since enrolling. Monthly loyalty reward indicated $1/mo
@afralick
The amount of credit/month is the number of years you are with PM.
When did you activate and created your account?
Contact a CS_Agent if not.
afralick
Will have to check files for welcome email.
afralick
Don’t have access currently to original signup documents but am reasonably sure it has been longer than two years.
afralick
Still on old rewards.
@afralick   Since you only still have $1 Loyalty, It should be easy to confirm.
If you login to My Rewards site
https://www.publicmobile.ca/myrewards
Go to History page, What amount showing for Loyalty Pays?  Let us know what you see
Timer
@afralick
maybe is will helpful
Rewards
Overview Of Rewards.
dust2dust
If you still have your welcome email from here then that is the date you signed up. You can also log in to the rewards page and click on discover points (don't click join!!) and scroll down to see the Anniversary points every year heading and your sign up date will be there. Don't click join!!
HI @afralick   exactly how long you have been with PM ?  If you are with PM for less than 24 months, and more than12, then yes, $1 is right
if you have suspended your account for couple months here and there, PM will delay it by those months before moving you in the $2 loyalty range
Maybe, you can also confirm how long you have been receiving $1 as well
Timer
@afralick
do you open new points rewards or you still on old rewards.
Edit: do you have refer a friend rewards
autopay rewards,
loyalty rewards,
use browser from computer, clear cache and cookies and use one page inPrivate mode,
to  Login Page and check out it.
