04-02-2019 11:17 AM - edited 01-05-2022 04:07 AM
Just wondering if anyone has done a plan change while on lost stolen mode.
current scenario:
So the question is will the plan change to the future dated plan while on lost stolen or does lost stolen trump the plan change?
another scenario: change to a plan which is more costly than available funds, thus suspending my account, and then do a plan change while suspended, when I want to reactivate.
Curious if anyone has had experience with either of the two scenarios.
04-02-2019 04:10 PM
04-02-2019 02:41 PM
@will13am so basically in May I do an immidate plan change while in lost stolen then remove lost stolen mode.
04-02-2019 01:26 PM - edited 04-02-2019 01:29 PM
If an account is suspended through use of the lost phone feature, future dated plan change cannot be made. @mimmo , you can try it for yourself. The plan change feature will not work. This has been my experience as I have previously played around with this in an account that I have in suspension. The immediate plan change button does work though.
04-02-2019 12:52 PM - edited 04-02-2019 12:53 PM
@mimmo wrote:Yes @metropublic you can futuredate any plan you want. If you have no funds or don't have autopay enabled then the plan change occurs and you go into suspended status.
@mimmothanks I was not aware that could be done. So then, that second scenario should work if the account goes into a suspended status.
04-02-2019 12:44 PM
04-02-2019 12:42 PM
@slash407 can you please clarify/expand your answer? I do t really understand what you mean time to reset.
04-02-2019 12:33 PM - edited 04-02-2019 12:37 PM
04-02-2019 12:20 PM
Is it possible to change a plan that is more costly than available funds? I'm assuming that autopay is not setup so I would be very suprised if the system would allow you to make that change.
