12-03-2016 03:00 PM - edited 01-05-2022 01:09 AM
I lost my sim card and emailed support to get a new one sent out, they have not replied yet and i am in urgent need. I have heard people saying they take weeks to answer.
Is it possible for me to just order a new sim card and activate it and use my old plan? I can't create an account because i have no sim card and thus can't manage any details of my account online.
Service
12-03-2016 07:12 PM
12-03-2016 06:49 PM
I agree with @jheili99. I always try to have an extra sim on hand
- incase a friend wants to join, I can say here is a sim lets actiavte you now 🙂
- if i lose one or it stops working (doen;t happen often but...)
12-03-2016 03:10 PM
then you would have a spare one , which many of us have anyways which you could use as a back-up or even as a referal to give to somebody else.... referals are paid 1.00 off/month/referal ....
cheers
12-03-2016 03:10 PM
Worse case scenario you paid for two sims.
But the advantage is that you could have your service back and running two weeks earlier.
@cheque wrote:Problem is i already emailed PM and if i order a new sim and it arrives in 2 days, what if they send me another one in 2 weeks?
12-03-2016 03:07 PM
12-03-2016 03:05 PM - edited 12-03-2016 03:05 PM
I think you can DIY this but doing it yourself always comes with the risk of screw up/tech issue which will require mod support.
Log into My account > Plan and Addons > Change Sim Cards> enter new sim and click submit.
Either way you can go ahead to order a sim or find one locally.
Others please chip in.
Bravo and/or mark as solution if this helps.
12-03-2016 03:04 PM
hi
once you receive your new sim card and you log into your phone account you will see the option to "change sim card" ....
there are a few people here in the forum who might have spare sim cards..worth a try and asking here in the forum....
cheers
