03-20-2023
07:04 AM
03-20-2023
11:13 AM
computergeek541
My number is attached as a 2nd factor authentication for many important accounts. I need this number back...
03-20-2023 10:12 AM
Depending on what make of phone you have.
You can login to your phone account and check on Find My Phone and see where it is located.
Then purchase a new SIM and click on Change SIM Card in your account if you are on AutoPay.
If non-payment is longer than 90 days then the number is lost.
03-20-2023 08:01 AM
@deeschmizz2 sorry to hear this.
Have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create My Account or forgot My Account email or password link
Or, when you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device) and your number cannot be found, then your account (and likely number) is gone.
03-20-2023 07:57 AM - edited 03-20-2023 08:01 AM
@deeschmizz2 how you lost your phone number?
Was the account permanently closed due to non payment for over 90 days after suspension?
If your account was suspended for less than 90 days, you can login back to My Account and reactivate the service
But if you account was over 90 days suspension, yes, it will be permanently closed. Can you get back your number? You might or might not be.
If the number was ported into Public Mobile form another provider other than Koodo or Telus, the number would have been returned back to the original provider where you got the number from and PM would not be able to help. You need to check with that original provider
If you got the number from PM/Koodo/Telus, there is a slight chance you can get it back , but usually only if the account was closed not long ago.
So, where you got the number from originally? And how long you lost your service with PM?
03-20-2023 07:14 AM
@deeschmizz2 You may need support to help
Watch for reply top of page to the
Right ( envelope image )
