08-14-2019 12:35 AM - edited 01-05-2022 06:24 AM
Hi there. I just got a sim card with public mobile and my number changed over. I was out hiking and lost my cellphone.
My question is, will the messages that were sent to me while my phone's off come through once I get it back and running?
How would I now go about getting a SIM for the new android phone I bought and keep my plan?
Thanks for reading.
Joining Public
11-16-2019 05:29 PM - edited 11-16-2019 05:32 PM
First off, @Josephklam it is best to start your own thread rather than posting on an old one. It get's peoples attention and causes less confusion.
https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/self_serve
However, I would say to report your phone lost (immediately) in "my account", buy a new sim (and phone) change the sim card number on your my account and then report your phone found.
11-16-2019 05:20 PM
I lost my cell phone while travelling and my sim card along with it. How can I deactivate my old sim, get a new one while saving my old telephone number.
08-18-2019 12:32 PM
@GinYVR wrote:@rassohanicoleSounds like your number got ported out by someone (perhaps the person who got your phone?). I would start changing your passwords (not the Public Mobile one but ones that rely your phone number for verification) and report to Canada Anti Fraud Center.
I would go a step further and change any active 2FA to another method (and revoke any 2FA authorized devices you might have).
08-18-2019 12:05 PM - edited 08-18-2019 12:06 PM
08-18-2019 12:05 PM
@rassohanicole hi if you try to many times you will be shut out for an hour or so if you still cant get in contact a moderator and tell them your issue here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-18-2019 12:02 PM
hello, I lost my phone a couple of days ago and couldn't find it. I wanted to block my number so no one can use it but I can't sign in to my public mobile account. Every time I try it says that I put the wrong password. I've pressed on the forgot your password button but it says that I do not have an account. I know I do because I remember using it months ago. I also still have the emails of the conversation I had back then.
thank you
08-14-2019 01:39 AM
Thankyou for the reply. Will let you know if they have it or not.
08-14-2019 01:20 AM - edited 08-14-2019 01:35 AM
@epsteinsbody wrote:Can I buy a new public mobile sim in a store (Courtenay, BC), or am I going to be screwed for two weeks waiting for it to arrive?
Cheers.
London Drugs down at Cliffe & 26th sells them. They'll open at 9am tomorrow. (If they are out of stock send me a Private Message.)
08-14-2019 01:17 AM
Cheers.
@epsteinsbody You can purchase a PM sim from a number of retailers. Best to go on the publicmobile main website and use the store locator feature to find the closest location near you.
08-14-2019 01:02 AM
Cheers.
08-14-2019 01:00 AM
@epsteinsbody wrote:A bit confused. Does it have to be a specific Public Mobile sim card?
Also, couldn't find any answers on whether or not the messages people sent after my phone was lost a couple weeks ago would be saved.
Cheers 🙂
Must be a new Public Mobile SIM.
Messages sent while the phone was on and had signal and had not been suspended will be on the phone. Otherwise messages usually only queue for a few days. So prior ones might be gone.
08-14-2019 12:51 AM
Cheers 🙂
08-14-2019 12:50 AM
@epsteinsbodyGet a SIM card, log into your selfserve and go here.. Remember to setup your APN to get your MMS and data working.
HOW TO CHANGE YOUR SIM CARD #
08-14-2019 12:43 AM
Hi
This thread could be useful in your case
It says that you can keep the plan on the new sim card via the Self-Serve site. Log in there, click "Plan and Add-Ons" at the top and then "Change Sim Card".
08-14-2019 12:41 AM - edited 08-14-2019 12:43 AM
@epsteinsbody wrote:Hi there. I just got a sim card with public mobile and my number changed over. I was out hiking and lost my cellphone.
Thanks for reading.
Simply get a new SIM and use the Change SIM feature in the self-serve.
Edit: use the Lost/Stolen feature first to disable the current SIM. Then re-enable when you're about to change it.
