07-03-2023 09:04 AM
Good Morning Community,
I have an extra phone that I registered with PM 6 or 7 years ago, as a spare phone on our Farming operation. It has been misplaced recently. I can't seem to get the account to sync up with eversafe as i havent logged in in the past few years. As I no longer have the phone for the security codes, i created an account using the email im pretty sure is linked to the phone, but it wont come up with the phone "account" details....not even sure how to cancel the recurring payments 😄
Not sure what my options are, any thoughts are welcome.
Thanks!
07-03-2023 10:44 AM
@jonvt - sounds like you just want to cancel this account? If so, if you know the 4 digit account PIN call # 1-855-478-2542 or # 1-855-4PUBLIC from another device and remove autopay. Then in 90 days in nonpay status this account will be automatically closed.
07-03-2023 09:22 AM
To be certain, is it your goal to cancel the account altogether, or reinstate service with a new device (for which you'd need a replacement Public Mobile SIM card)
If CANCEL, contact support and ask them to remove the associated auto-payment trigger and the account will suspend and terminate without further payment.
If RESUME with new device, get a PM SIM card from a corporate TELUS, Koodo, or Mobile Klinik location, then regain access to the self-serve to do a Change SIM card function on the existing account. Once the new PM SIM card number is entered in that area on the account, simply pop it into the replacement device.
Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
07-03-2023 09:16 AM
@jonvt Get a new SIM card and if you can get support to help you regain access to it you can sim swap the sim number to keep the phone number and plan like this
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
or you can ask support to do this for you if your having issue with it . Also if you just want to to cancel the account you can port number out or turn off auto pay like this
Turn auto pay OFF/ON 3 easy clicks
Or you can ask support to remove the credit card on file to cancel account right away
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
07-03-2023 09:13 AM - edited 07-03-2023 09:14 AM
if you cannot find the email linked to the phone, or you got the correct email but not working, you will have to submit a ticket with PM support me have them to help. Please message them here:
