12-23-2019 07:21 PM - edited 01-05-2022 08:41 AM
So I just suddenly lost network/connection/signal. Everything was working fine when i purchased the SIM card a couple weeks ago. And now all of a sudden i have no signal. It doesnt even say the network name on the top left corner of my iPhoneX where it use to say Public Mobile. Anyone know how to fix this or can point me in the right direction? Please and Thanks!
12-24-2019 10:26 PM
You can try to restart your phone. Sometimes it works.
12-23-2019 10:47 PM - edited 12-23-2019 10:51 PM
Check if your phone is lost or stolen.
Enter your 15 digit IMEI number. You can find it by dialling *#06# on your phone.
Also you can check here to see if it was blacklisted
https://www.devicecheck.ca/check-status-device-canada/
Only the person who reported a phone stolen can have it removed from the blacklist. If you purchased your phone through a classified listing (like kijiji or craigslist) then your only option is to contact the seller and ask for a refund or to remove the phone from the blacklist (if they were the ones who put it on).
12-23-2019 10:36 PM
@samc888 If your sim works in another phone then you phone is blacklisted. No much you can do that is why it's important to buy a used phone from trusted sources only.
12-23-2019 10:29 PM
@samc888 wrote:@geopublic
How would I know if I was blacklisted? And if my phone was indeed blacklisted, is there a way to have it working again?
Google iPhone blacklist checker. Try different free sites to check if it's blacklisted.
If it is. You have an expensive iPod
12-23-2019 10:20 PM
@geopublic
12-23-2019 08:02 PM
@samc888 wrote:So I just suddenly lost network/connection/signal. Everything was working fine when i purchased the SIM card a couple weeks ago. And now all of a sudden i have no signal. It doesnt even say the network name on the top left corner of my iPhoneX where it use to say Public Mobile. Anyone know how to fix this or can point me in the right direction? Please and Thanks!
If you loose Network all of a Sudden, it usually means you bought your phone from a 3rd Party. Eg. Craigslist, Kijiji eBay etc. The Person you bought it from Reported it lost or stolen. I am almost certain this is what happened.
12-23-2019 08:01 PM
@samc888 Maybe your phone got blacklisted?
12-23-2019 07:54 PM - edited 12-23-2019 07:56 PM
Any chance that where it was working fine earlier, but not working now, are in two different places? What I'm getting at is, are you in an area, like I am, where reception is spotty? In my case, I can lose the signal when I go down the hallway from where I'm at right now..... sometimes the signal re-connects, by itself, when I move to a spot with better reception, and other times I have to go into the network settings, and click on the PM network to get it connected again.
12-23-2019 07:27 PM
I did... many times actually. But still not working.
12-23-2019 07:26 PM
Unfortunately i have no other phone I can put the sim card in. The weird thing it was just working fine earlier and BAM! Suddenly no signal
12-23-2019 07:24 PM
Try rebooting phone?
12-23-2019 07:22 PM
Can you try another phone to see if it's sim/service or the phone itself
