What network does Public Mobile use in Mexico?
bobca420
I'm planning on taking a trip to Mexico and was wondering what network Public Mobile roams on when in Mexico.
hairbag1
@bobca420
depends where you are. I'm currently in Mazatlan and AT&T seems to be the predominate network, but I've seen Telcel and Movistar shown as network. To dial a Cdn number using Public Mobile, you need to subscribe to the Canada / Mx / US plan, and start you call using +1...area code...number. We found it works great....and the taco's aren't too bad either.
@bobca420
Just set your phone on Roaming (Auto) and it will connect you with the PM partner in Mexico.
ORNGNBLK
@bobca420  depending on where you are travelling you may see any of the below to connect to: altan AT&T Nextel Telcel Telefonica, movistar.
