Long distance calls
ajfedinaz
Do I have to pay extra for long distance calls to other provinces in Canada?
ajfedinaz
Thank you
gblackma
@ajfedinaz add a free voip app such as TextNow and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. Welcome to the community. Stay safe.
geopublic
@ajfedinaz  Only if you are on a province wide calling plan. As mentioned already all the current Public Mobile calling plans include Canada wide calling.
Public Mobile is a prepaid service so there aren't any long distance charges. It works or it doesn't. If it doesn't work then you need to purchase the 500 minute calling add-on for $5.
Triguy
All of the recent plans $25 and up have free long distance calls within Canada.  The $15 plan has 100 minutes of Canada wide calling.
