Long distance calls
12-05-2016 02:12 PM - edited 01-05-2022 01:10 AM
Good day, I just renewed my plan on December 2nd, 2016 and since the beginning I'm unable to dial any 819, 438, 514, 450 numbers. I had to add 200 mns of long distance to use my phone and I have a province wide plan. Can you please fix it because I don't want to add any more long distance plan? If I have a Quebec plan, I should be able to dial any number to Quebec from Quebec. I live in Gatineau, I can't even call any local number. I'm waiting for your answer to fix the issue. Thank you !
Service
12-05-2016 05:51 PM
@kenny wrote:Even in Gatineau, I can't make the calls. It always said that I need a long distance plan. The last time I had to buy an additional 200 minutes.
@kenny its not really an issue where you are as much as which tower you are on
I have same issue with Niagara Falls when it jumps to US towers despite being in Canada
12-05-2016 04:13 PM
@kenny the problem is that depending where you are in Gatineau, your phone can still be connecting to a tower in Ottawa. It's a huge flaw in PM's system for province-wide plans, that they don't handle Gatineau very well. Same thing happens when you're near the US border - your phone ends up connecting to US towers sometimes if it finds a stronger signal there.
12-05-2016 03:44 PM
I already sent a message about this and I'm still waiting for an answer.
12-05-2016 03:44 PM
12-05-2016 03:17 PM
Private message any moderator with your phone number and an explanation. The backlog is such that it may be several more days before you have a response. Suggest you create a way to cope with that delay. If you decide to purchase the long distance add-on to get by for now, ask for a credit.
12-05-2016 02:25 PM
@kenny it is only a free call while in Gatineau on a Gatineau cell tower. If you cross into Ottawa or get picked up by an Ottawa tower your service won't work.
Click here to bravo and promote the idea for allowing the capital region to be seen as local. We wanted to get Public to correct this issue as soon as possible.
http://productioncommunity.publicmobile.ca/t5/Public-Lab/Ottawa-ON-Gatineau-PQ/idi-p/83112
