03-04-2020 10:07 PM - edited 01-05-2022 09:47 AM
Hello,
I get a long distance calling not active message when i call my wife's freedom number. Even though she is sitting beside me.
03-05-2020 08:24 AM
Thanks yes both our numbers have 647 as first 3 digits.
I will reachout to a moderator.
03-05-2020 08:22 AM
No i don't have canada wide calling. I don't use it so i didn't opt for it.
And I don't wish to pay for something that is public mobile career problem.
03-05-2020 08:20 AM
No she hasn't blocked me
03-04-2020 11:48 PM
03-04-2020 11:46 PM
@Rushabh wrote:Hello,
Her sitting beside you doesn't mean much. What's important is which city are you in now and which city is her phone number from?
In any event, when it comes to the suggestions about dialing the 1 before the area code of your wife's phone number, that should not do anything other than allow you to skip a remdinder message that the call is long ditsance. That's all dialing the 1 should do, and after listing to such a message, the phone call should complete.
What is the exact wording of the message? Is it saying that long distance isn't included in your plan or that "talk" isn't included? If it's giving one of those error messages, this is likely a provsioning/setup issue with your account.
03-04-2020 10:36 PM
@Rushabh Try dialing the number directly. That error usually occurs if your are trying to call a US area code. Check the number in your contacts.
03-04-2020 10:35 PM
@Rushabh Check the CNA code website . To see if as @zblackma mentions above. If one set of numbers isn't local to the area. Thanks
03-04-2020 10:30 PM
@Rushabh what area code is your wife's phone and what area code is yours?
Is your wife's by chance 647?
This is an older link..2017 with an issue from 647 area code....
They had to contact moderators to fix.
However recently there has been a few new area codes introduced in Canada. Maybe her area code is a new one???
To reach moderators there is two options.
Or private message them at link below.
03-04-2020 10:21 PM - edited 03-04-2020 10:25 PM
@Rushabh wrote:No i have this number and have been with public for 5+ years.
My wife recently got the freedom number but other people can make calls to her number.
I have tried rebooting the phone also tried with calling with +1 same response.
Yes she can call me with no issues
@Rushabh What plan are you on. Do you have Canada wide calling or are on an older plan with only provincial wide calling? If that is the case purchase the $5/500 Canada wide minutes to supplement your plan.
03-04-2020 10:18 PM
What's the make and model of your wife's phone @Rushabh . Could you check it to see if she blocked your number by accident? Thanks.
03-04-2020 10:14 PM
03-04-2020 10:13 PM - edited 03-04-2020 10:15 PM
@Rushabhtry dialing a 1 in front of the number. The second 3 number set of digits for one of you may not local to your area. 1 xxx yyy xxx.
03-04-2020 10:09 PM
Have you tried adding +1 in front of her number before calling.? Actually adding +1 in front of all numbers is a good idea.
03-04-2020 10:09 PM - edited 03-04-2020 10:10 PM
Did you just port your number?
Have you tried rebooting your phone?
Have you dialed her number with a 1 infront of it?
Is it only this number with issues?
Can she call you?
