02-09-2020 07:09 PM - edited 01-05-2022 09:25 AM
I Have 200 minutes US and Canada long distance, as a standard add-on. Yet when I try to call home from Daytona I get the message that I don't have that add-on. On my account it clearly shows that the add-on is activated (and has ALWAYS been activated since inception).
Please advise.
Thank you
02-09-2020 07:15 PM
@bradyjc The add-on you have is not eligible to call From US to Canada. You need the US Roaming add-on to call from USA to Canada.
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
02-09-2020 07:11 PM - edited 02-09-2020 07:12 PM
Are you putting a 1 infront of number? And are you calling from Canada ?
02-09-2020 07:12 PM
@bradyjc Uhm.... when you try to "call home from Daytona".... shall we assume you mean, FROM the US? If so, that add-on is for calling FROM Canada, not TO Canada.
02-09-2020 07:14 PM
@bradyjc wrote:I Have 200 minutes US and Canada long distance, as a standard add-on. Yet when I try to call home from Daytona I get the message that I don't have that add-on. On my account it clearly shows that the add-on is activated (and has ALWAYS been activated since inception).
Please advise.
Thank you
Those add-ons are only good when you are located in Canada. If you are in the US you will need a US Roaming add-on to be able to call back home.
02-09-2020 07:15 PM
02-09-2020 07:15 PM
If you're in USA you will need a USA roaming add-on.
$8 for just talk from USA to Canada. There is also text or bundle options.
Two steps to buy an add-on. Guide below.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/td-p/198974
02-09-2020 07:18 PM - edited 02-09-2020 07:19 PM
Or you can use 611 to do it @bradyjc . Guide here https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352/highlight/t...
02-09-2020 07:28 PM
Thank for the response.
Yes I added a "1", and no I am calling from the US.
02-09-2020 07:30 PM
@bradyjc wrote:Thank for the response.
The 200 min add-on you're talking about is from Canada. You will need a USA add-on to call from the states. See above I posted two step guide to buying an add-on
02-09-2020 07:31 PM
Thank you to all for the clarification.
Clearly I misunderstood what I had, which is completely useless to me in Canada.
While I have your attention may I ask why I can recieve texts in the US but cannot send any?
I did buy a data plan, but just data.
Thanks all
