01-23-2026
08:28 PM
01-24-2026
05:17 PM
computergeek541
I checked the countries listed that long distance calls can be made to but I did not find any African country on the list. Any reason?
01-23-2026 09:17 PM
01-23-2026 08:40 PM
hi @Mensahk
you don't find it there, then sorry, you cannot use it to call
you will have to go back to use calling card to call
01-23-2026 08:39 PM
@Mensahk Probably has something to do with the fact public mobile is tier 3 provider you need tier 1 provider like Telus and you will be able to call Africa
