01-23-2026 07:41 PM
I got the Error Code: M.8702 when subscribe the servie, pls help
01-23-2026 08:47 PM
were you only using the app? or just use the browser? you need to use the app, and this is related with the current ongoing issue
01-23-2026 07:43 PM
the service does not work?
Ask PM to check. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
01-23-2026 07:42 PM
hi @Mika121
I did a quick search and seem like it is a very common activation today or even this week
Please submit ticket with PM support agent and they will resolve it. Submit ticket by direct message:
01-23-2026 07:42 PM
