06-27-2017 09:00 AM - edited 01-04-2022 02:13 PM
06-27-2017 11:40 AM
Also, if you do not have a LongDistance add-on, the call will not go through, period. So if the call goes through, it is inlcuded.
But ya - it's a pain
06-27-2017 09:08 AM
This is normal. Also, since PM is prepaid, if it is really is long distance (out of province or country) you would not be connected, if you did not have a LD add-on. So, just ignore the message. That's one of the good things about PM, if you can make the call, the cost is already covered.
06-27-2017 09:07 AM
Its a prepaid plan, you cant call outside your local area.
For long distance inside my province, i always have this message, its normal, i think its a telus warning or something like that.
Need more help?
06-27-2017 09:05 AM
This is standard.
Every call outside your city is "long distance" however your plan covers province wide, so let the call go through (or put 1 first to ignore that message).
If your plan does not have a long distance package the call will NOT go through since PM is a pre-paid service. you will not be billed for anything after the fact. If you do not have you do not get to use, simple.
