Login
DeelightfulDee
How do I access my account?
I'm in the password reset loop with eversafe not recognizing my password. I've cleared my cache, rebooted my device, changed browsers, changed devices. I'm at my wit's end with stupid eversafe.
Thanks
Do I have to contact support to get this fixed? Assuming yes?
13 REPLIES 13
DeelightfulDee
I can get a voucher that's not the issue as I need to change plans first. It would be easier if the agent would just update the card. If a customer can't change their own card and an agent won't I have to escalate my support request? What's next ask the CRTC to help me login? I had no idea that customer support here was so useless?
@DeelightfulDee
Support can actually help to remove your credit card from the system
I believe they can help to update it, too, I guess YMMV
You urgently need to resume service? Maybe you can buy a voucher from SDM/711/Shell/London Drug and load the voucher using *611
But if you really need to get back into My Account, please work with Support on that as they might be the only one able to fix the password reset loop.  If you are not satisfied with the replies you got so far, ask them to escalate and have a senior support staff to help
DeelightfulDee
Okay this is just getting dumb and dumber! I keep getting asked what process I've used to login which I have explained and I get asked the same question by the same agent over again so I asked if I can get my credit card updated so I can get my subscription up and running again and no apparently they can't change the credit card on my account but I can't remove my credit card on my account even if I could get in so who has access to removing and adding credit cards? P this cannot be the first time this agent has been asked these questions why do they not have an answer rather than giving me the same answer that the community gave me 3 hours ago?
DeelightfulDee
Wow is this how customer service works here? Initial contact with a few suggestions that I had already tried and nothing,? It seems I'm getting the exact same response from the community and customer support agents?
BTW according to the agent the resetting of the email to the account fix is incorrect?
DeelightfulDee
I've been contacted by customer support. Although I'm not so sure they can fix my issue because all they told me to do is to clear my browser or try a different one? Hopefully after I told them what the apparent fix is thanks to hTideGnow's explanation the agent will fix the problem?
@DeelightfulDee
Yes, your Community email will be merged to your account email.
DeelightfulDee
Thanks. I have to change my email anyways maybe if I had done that when I created my eversafe ID that would have avoided this problem?
HI @DeelightfulDee
you login with the same email address you used before?
it is a profile issue, PM has to unlink the My Account with the email address and relink it to resolve the problem
DeelightfulDee
Thanks. Does anyone know what they do to fix this?
HI @DeelightfulDee  you have already tried clear cache and different browser, I think you need to submit ticket for agent's help
DeelightfulDee
Done all that. I don't have access to a PC. Phone and tablet only.
@DeelightfulDee
Tap on Resend Code and have the 2FA code sent by email to access your account. Make sure you click on Trusted Device so it will be easier to login to your account in the future.
If all fails, contact a CS_Agent and have them help you access your account.
Meow
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Interesting how Some customers always have an issue while other fly through PM site like on a cloud.
I NEVER had any issue with logging into PM site using computer. Like NEVER. Any hiccup if ever occurred was resolved with simple refresh. Chrome, latest version, ordinary PC laptop.
