11-25-2023 09:16 PM
11-26-2023 01:34 PM
Hello John.
This is a widespread problem. I cannot log into my account, too. No verification codes are sent to email / phone, and without them, I cannot log in. I complained million times, but incompetent customer service agents are not helping, they are just wasting time. It's a system that has serious glitches, and nobody is fixing them.
I would recommend you to cancel your account. I am also trying to cancel mine.
11-25-2023 11:53 PM
Is the issue with access (password?) or just that it never logs in? I’ve been noticing issues with the latter the last few days and I suspect it may be due to an influx of member flooding PM to view/change their subscription to one of the BF promos. I find it’s easier to log in early in the morning or late at night when traffic to PM is likely lower
11-25-2023 11:18 PM
@Johnzhai If you clear your cache and/or use an incognito web browser, does that help your login process? If not, is your issue password or email related? If so, perhaps you might need to click on the "Forgot Password" option at the login screen.
Please provide us with a bit more detail of what issue you are getting at the login. Thanks
11-25-2023 10:57 PM
Wedsite still too slow,regress you page
11-25-2023 09:17 PM
@Johnzhai Submit ticket with support to help you gain access
send a private message To CS_Agents click
VVVVV Link below VVVVV
11-25-2023 09:17 PM
If you're having issues logging in, go into your browser settings and clear your cache, history and cookies. You will however have to wait 1 hour before you can try to log in again as you're blocked for an hour.
11-25-2023 09:17 PM
try to restart computer or use another one
