Login issue
Raidbiram
Good morning . I used to login normal. I have my email and passward, but since i updated the app and want to login again, the app log me in and verify my number BUT asking me to choose subscription and going through all the questions for someone shoping !! I only need to log in in my account like before and view my history , add on . And so on. Can you help please
2 REPLIES 2
@Raidbiram  If your not able to log in get support to help you regain access to your account
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
slusagm
for some unknown reason, the system lost the tie between your email login and My Account.  Did it shows the same when you use browser with Incognito mode?  try and see
if you cannot login on browser with incognito as well, ask PM to help.
  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
