11-19-2022 04:28 PM
I've recently had trouble logging into my account. I get page no longer exists message. I reset my password and now I have a different page error that says message unauthorized. What is going on? I want to add data.
My Account
11-19-2022 09:11 PM
You are not alone I have been trying to access my account for over 2 months changed the password 100 times now it started saying no such email I tryed everything and every suggestion they given and that chatbot is useless I think it's time to change carriers
11-19-2022 07:56 PM
@Joooo- I think I just had the same thing. I refreshed the page and it went back to login and then I was able to login as normal.
11-19-2022 07:47 PM
I am having the same problem with the message unauthorized
11-19-2022 04:32 PM
Hi @Holly4
try clearing cache and restart browser
Or try to use Private or Incognito browser mode
Or try on another device
and when you try this time, use the newest password you just reset to
11-19-2022 04:30 PM - edited 11-19-2022 04:31 PM
@Holly4hi try using a different browser in private or incognito mode try to log in again if that doesn't work
to reset account password/ email you need the help of a service rep if simon won't work for you use option 2
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
