05-30-2023 09:59 AM
When I try to log into my account out of Canada, it asks me for a code sent via messaging as usual. However, since I am overseas I won't be able to receive the messaging so I cannot sign in the account and make changes?
05-30-2023 10:10 AM
Before contacting CSA, there are a couple of tricks that may work to get into your account:
1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
2. When asking for SMS text, keep entering wrong codes 4-5 times and sometimes, an email verification will be sent.
Keep an eye on this announcement when Public mobile has determined a fix:
05-30-2023 10:07 AM
Too bad I have not gone through eversafe login before yet so I have sent a private message to the CS agent per above. Thanks.
05-30-2023 10:03 AM
@TimC - if you have not set up your EverSafe login information, you can use the Get Help section: https://www.publicmobile.ca/en/ns/get-help, type 'customer support' to get methods to Public Mobile representatives to help you get logged in.
05-30-2023 10:02 AM
05-30-2023 10:02 AM
@TimC , if you have already gone through the eversafe login, you can simply select resend which will give you the option to receive the 2FA code to email.
