Locked out
alexcruze
I need my account number
2 REPLIES 2
Yummy
Click on Profile, scroll down, look at right hand part of the screen. Hover mouse over crossed eye and account will be revealed.
HI @alexcruze
Yes, you need to login to get your Account number from the Profile page
Sound like you cannot login , try using Reset Password
If still unable to reset password and login, please open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
