Locked out
Cameron8885
I need to access my account and I’m locked out.  Won’t allow me to resetbpassword
2 REPLIES 2
Dunkman
@Cameron8885
If you are locked out, try again in one hour.  Then you can reset your password after the one hour lock period.
https://selfserve.publicmobile.ca/forgot-password/
If that does not work, then you will need to submit ticket for customer service agent help.
https://www.publicmobile.ca/en/on/chatbot
@Cameron8885
Have you ever created a self serve account before, if not you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
If you have created a self serve account and you are having issues logging in, try clearing your browser's cache, or try a different browser or device. Opening a tab in incognito mode may help as well.
Also, too many failed attempts may temporarily lock your account access. So wait 15+ minutes before you try again.
If having issues with your password, use the Forgot your password option again to reset it, found here: https://selfserve.publicmobile.ca/forgot-password/
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
