03-18-2022 02:29 PM
I am the executor of my fathers will and I am locked out of his phone plan. I have been trying weekly for about a month. The credit card attached to it isn't being cancelled.
I have his pin and access to his email to reset (as well as Will showing executor status). HELP!
03-18-2022 02:32 PM - edited 03-18-2022 02:35 PM
if you have the 4 digits PIN, you can call *611 to disable the Autopay
or for access to My Account back,
try to open ticket with PM support to reset
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
type: Change username
Click " Forgot Self-Serve Email"
Click "Contact Us"
Click "Click here to submit a ticket"
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
