Locked out sim card
paulas
Galaxy A12- went to put in a pin number for sim card first time, asked for code, tried 0000, 1234.  Now I'm locked out.  Asking for PUK.  Also kept saying "possibly incorrect pin "
Please advise.  Thanks
2 REPLIES 2
@paulas
You can get the SIM PUK by contacting a CS_Agent by chat or private messaging on this Community page.
You might need a PUK for unlocking the Samsung phone. You will need to contact Samsung Canada if your phone was purchased in Canada at 1-800-726-7864.
Meow
Find your PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
- SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
- SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
- PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
