Lock out
Lagab88
Hello I got lock out my public mobile account. I forgot security question answer
if you already tried the Forgot password but cannot answer the security question, you will have to open a ticket with PM to get your password reset,
At Chatbot (https://publicmobile.ca/chatbot), type the follow to get to ticket open screen quicker:
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
Triguy
Try waiting an hour.  Also try using a different browser and incognito mode.  Also clear your cache and cookies then reboot.
Dunkman
@Lagab88
Your account gets locked out for about one hour.
You can try again in one hour.
Try reseting your password.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If not working, you will need to customer service agent (CSA).
You will need to contact customer service agent (CSA):
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact CSA.  Type: I can't login.  Follow the prompts to submit ticket.
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours.  Check your private message inbox (envelope in upper right corner of website).
