01-28-2021 05:59 PM - edited 01-06-2022 01:57 AM
Every time I try to make a call it says its long distance when its not
01-28-2021 06:17 PM
Consistent with @computergeek541 advice, I would update your contacts so that "1" is in front of every area code.
01-28-2021 06:00 PM
@dvoce75 wrote:Every time I try to make a call it says its long distance when its not
If the messages says that "long distance charges may apply", you can ignore the messages. There will be no charges. The messages can be avoided for future outgoing phone calls by dialing a 1 before the area code.
