06-04-2018 04:51 PM - edited 01-04-2022 06:06 PM
Hi,
I’m trying to make a call local call within same province. However, I get a recorded message saying, “sorry, you do not have active long distance add on...”
Why am I having this problem all of sudden?
I have $120 plan with unlimited call within same province.
10-12-2018 09:30 PM
Hey Dunkman!
Text is the only other feature on this phone/plan and yup works fine. Have sent aprivate msg to moderators in the mothership. Fingers crossed the solution will come soon.
Thanks for the assist.
Cheers!
10-12-2018 09:22 PM
If your plan is active and you can't call within your province, you might need to contact moderator. Does eveything else work? Text? Data? etc.
send a private message through the following link :
Please include in the private message your phone number, your account number and PIN code.
10-12-2018 09:12 PM
The solution provided (adding +1 to the number dialled) isn't working. Any other options?
Cheers
06-04-2018 11:57 PM
This problem is generally due to account provisioning issue. Contacting the moderator team is the solution.
06-04-2018 08:30 PM
Thanks
06-04-2018 04:57 PM
@oceanwind I got the same problem like you awhile ago and I contacted Mods they solved that problem for me really quickly.
06-04-2018 04:54 PM - edited 06-04-2018 04:59 PM
Add +1 to the number you dial and ignore this message!
If it is annoying for you, send a private message to a Moderator_Team, they will check provisioning on your account and resolve your problem!
Here is the link: click here
In your message, please provide your name, Public Mobile account number or phone number and PIN.
Good luck! ![]()
Contact Support hours of operation:
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:30PM (EDT)
