06-19-2019 10:38 PM - edited 01-05-2022 05:28 AM
Since last week, when I do outgoing calls, it keeps telling me that my call cannot be complete because I don't have a active long distance plan. But I am calling my son which is local. Can anyone assist? I have a $10.00 per month plan.
Thanks
06-21-2019 11:31 AM
'Local talk' in terms of landline phones does not exist at Public Mobile. Old landlines could call locally across provincial boundaries, even into different area codes because they were geographically 'local' to the area.
The minimum $10 plan has a 'free' call for 50 minutes (always rounded up to the next full minute) for combined usage of incoming and outgoing calls to anywhere in Canada.
If you truly still have minutes remaining in your plan, the same error message will happen if you misdial the number. Please try redialing directly, or updating your contact list info, in case something has changed in that record.
06-21-2019 11:26 AM
@popping wrote:
@STong wrote:Since last week, when I do outgoing calls, it keeps telling me that my call cannot be complete because I don't have a active long distance plan. But I am calling my son which is local. Can anyone assist? I have a $10.00 per month plan.
Thanks
The $10 plan has 50 minutes per 30 days cycle.
Login to your self-serve account.
Do you see following usage line at the "My Data & Add-Ons" section
Limited Canada-Wide Talk 4 / 50 MINIf you don't see this line, you had used all your 50 minutes.
You can purchase the $5 for 500 Canada wide minutes add-on. Minutes add-on does not have expiry date. Any unused minutes will be roll-over to next cycle until all your add-on minutes are used.
@STong, can you copy for us the same information that @popping has made bold in their post I've quoted here? There will be a difference between the text on your 'regular $10 plan' calling minutes, and that of any add-on quantity of minutes.
06-20-2019 04:14 PM
HI,
What is your area code you are going to dial? And, what is your local area code?
Thank
06-20-2019 02:39 PM
06-20-2019 02:25 PM
Is there any message given to you about the lack of calling ability?
06-20-2019 02:19 PM
I have check the usage, and I haven't use them all up yet
06-19-2019 10:52 PM - edited 06-19-2019 10:53 PM
Thanks
Limited Canada-Wide Talk | 4 / 50 MIN |
06-19-2019 10:43 PM - edited 06-19-2019 10:44 PM
if your minutes are gone you can purchase a 500 minute add on they will be on your account until all used up
06-19-2019 10:40 PM - edited 06-19-2019 10:41 PM
have you checked to see if your minutes are used up you only have 50 go into your account to view usage
