Load
Sansan
Why does the system take so long to load?
Amped
The app is pretty slow too!  I just opened it and it took about 20 seconds before my plan usage finally loaded up.
HALIMACS
@Sansan
It's certainly not just you.
When I am trying to access the public mobile self-serve site, be it through mobile, laptop, or the app, it takes an infuriating amount of time for the page to access and fully load.
Clearing system cache & cookies, using Incognito or private tab has no impact.
Good time for a break while it is waiting to load  😉
The Public Mobile Self Serve website and app are slow, likely due to resources used to connect to that server, and/or software coding for the website that could use some improvement.  The app ususally works more quickly.
