List of phone calls from December
hennady
Hi,
My account shows only phone calls made during last 30 days.
Is any way to get access to a list of calls I made back in December 2019?
Thanks,
Hena.
geopublic
@hennady wrote:
Hi,
Thanks,
Hena.
@hennady  What type of phone do you have? If you use Android go into your Google Settings and Preferences  and see if the calls are showing up in your logs.
gblackma
No @hennady it goes back only 3 months. You can try contacting the moderators and ask them if its possible. There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe. And good luck.
popping
@hennady wrote:
Hi,
Thanks,
Hena.
Instead of using the fixed last 7 days or last 30 days, you can select using start and end date for up to 1 year.
Sorry.  Max 6 months from self-serve portal.
Create a moderator support ticket to get last December call records.
