03-11-2024
01:20 AM
03-11-2024
02:44 AM
computergeek541
I'm new to public mobile. Finally received my physical SIM card after waiting a full week. Trying to link my SIM card to my account. After entering the number it says it is an invalid SIM card. HELP PLEASE!!!
02-02-2025 07:25 AM
@john-jiang The corporate Telus/Koodo stores carry them but you can call ahead to check on stock, see
02-02-2025 12:46 AM
do you mean that I can buy a Public Mobile sim in a Koodo store?
02-01-2025 10:31 AM
@john-jiang same issue as invalid SIM. any solution to fix this
The solution would be to purchase a Public Mobile sim card through Public Mobile (can be slow) or go to a Telus/Koodo store and buy one, or order one from Amazon. If your phone can do esim that would be the quickest solution. All cell carriers have their own individual sim cards, they are not interchangeable.
02-01-2025 09:19 AM
@john-jiang wrote:I am trying to link my koodo SIM card. same issue as invalid SIM. any solution to fix this?
Koodo Mobile SIM cards cannot be used at Public Mobile.
02-01-2025 09:18 AM
03-11-2024 05:39 AM
@Rtam18 Does the sim card say Public Mobile? There have been a couple of cases where a Telus or Koodo card was sent by mistake. If you need customer service you can open a ticket using the chat icon bottom right of the page. If it's not working you can send a private message to them using this link
An agent will reply either at the envelope icon if you see one or tap your avatar for Messages.
03-11-2024 02:14 AM
03-11-2024 01:26 AM
There is maintenance going on currently so that could be why you are encountering errors. However, please ensure that you have downloaded the Public Mobile App and following the instructions.
If so, you can submit a ticket here.
However, due to maintenance you will have to wait until probably after 6am to try again.
