6 hours ago - last edited 6 hours ago by computergeek541
My spouse and I are both on Public phone plan. When I connect with her and vice versa, I always notice a voice in our conversation. Does anyone have experienced this as well and how have you resolved it?
4 hours ago
HI @ITS
you got the problem only when you two call each other?
did you try the sim card in a different phone?
4 hours ago - last edited 4 hours ago
@ITS I have seen reports of this a few times before. I don't know what was the fix or outcome.
People have reported listening to entire conversations from someone else while they were in the middle of a conversation 🙄. They call had to hang up.
Not sure what causes it. You can use the chatbot to create a ticket and report to PM. Not sure what/if they can do anything.
4 hours ago
@ITS Is it like an echo (acoustic feedback), if so is either of you using speakerphone? Or is it a completely different voice?
4 hours ago
@ITS , that seems unusual. Is the signal strength pretty decent while you are on the call?
