09-07-2016 10:50 PM - edited 01-04-2022 03:12 PM
I tried setting up the APN and everything and it's still not working. I used to get lte around where I am when I was still with Telus so I don't know what the issue is.
My phone is a new Samsung s7 that I know is fully compatable with the Telus network because I bought it from Telus.
The max speeds that I am getting are 4g speeds, not LTE and LTE+ like I used to get.
I've already tried restarting my phone and checking to make sure autoconnect to LTE is enabled and it still hasn't worked.
What am I doing wrong?
09-08-2016 01:07 AM
@fisher wrote:i got download 4.1 mbps upload 1.5mbps
That doesn't sound like you're on LTE/4g.
09-07-2016 11:17 PM
good for you !!!
09-07-2016 11:17 PM
On the s7 it shows LTE as LTE and true 4g as true 4g, but its ok because I've figured it out now
09-07-2016 11:16 PM
i got download 4.1 mbps upload 1.5mbps ![]()
09-07-2016 11:16 PM
Ok nevermind.
After taking my sim card in and out again, I am now getting LTE+ speeds
09-07-2016 11:07 PM
What kind of speed test results are you getting? Usually on Android 4G means LTE. If you're on 3G it will show H+
09-07-2016 10:58 PM
Mark !!!
waiting for a solution!![]()
