04-01-2020 03:42 PM - edited 01-05-2022 10:11 AM
I have an LG Q6, model number LG-M703 and it is not listed under LG phones that are compatible. Can this be changed or can I just not have a plan with Public?
04-01-2020 06:59 PM
@smiles0 wrote:I have an LG Q6, model number LG-M703 and it is not listed under LG phones that are compatible. Can this be changed or can I just not have a plan with Public?
There is generally no way for an incompabile phone to be made compatible with Public Mobile. Being on the list isn't what makes it's compatible. While checking the list is generally a good idea, this list will never be 100% accurate or complete. A phone is either compatible or it isn't whether or not it's on the list. The list is meant as a general guide only.
04-01-2020 03:58 PM
@smiles0 According to https://www.frequencycheck.com/models/Az8wV/lg-m703-q6-lte-a-32gb it's 100% compatible
Public Mobile 3G & 4G Frequencies.
3G Frequencies 850 MHz, Band 5 (UMTS/ HSPA).1900MHz, Band 2 (UMTS/ HSPA).
4G Frequencies 1700/ 2100 MHz AWS, Band 4 (LTE/ LTE Advanced).
700 MHz A/B/C/E, Band 12/13/17/29 (LTE/ LTE Advanced).
It's basically got most of the PM frequencies so it will work. Make sure it's unlocked and do a factory reset before placing in the PM SIM.
04-01-2020 03:57 PM
It's the Canadian model so it should work just fine with Public. I don't believe it has Band 66 support so Freedom might be out of the question
04-01-2020 03:54 PM
@smiles0 will work without any issues. That model is the Canadian version so you are good to go.
