03-09-2019 03:01 AM - edited 01-05-2022 06:49 AM
Hello,
A family member gave me a AT&T gift phone the LG Phoenix # 4G LTE. She bought it brand new as a gift back up phone.
Can anyone advise if this phone will work on the Public Mobile Telus system?
I do not have the IMEI number since its at her house still in the box unopened.
Thanks
03-09-2019 08:16 AM
@Patrick_R a écrit :Hello,
Thanks
You can use the site...willmyphonework.com...to see if a phone is compatible or not...
03-09-2019 03:29 AM
The phone is compatible. as long as its unlocked.
If you have friend using public mobile, use their sim to test.
03-09-2019 03:24 AM - edited 03-09-2019 03:39 AM
@Patrick_R wrote:Hello,
It's compatible but you'll first have to get it unlocked. Also, I do not know of AT&T had any of device's features disabled in the software such as hotspot or the ability to change APN settings.
