Joining public
Kar68
@Kar68
You will need to follow these instructions if you are porting your old number over to PM:
The steps must be followed in exact order if you are porting your number over to PM:
  • Make sure your old SIM is active so DON’T CANCEL serviced with them.
  • Purchase a PM SIM from Amazon ($5) or Canadian Cell Supplies ($4) or pick one up from Telus/Koodo/Mobile Klinik store ($10.00) or eSIM from Public (ONLY if your phone is eSIM compatible so check).
  • Download the PM app on your phone to activate the SIM. There is an option to pick a new number or
  • Porting your old number = Use the old account number and not the IMEI to avoid issues. Complete to step 6. Note that your previous service is Koodo prepaid…you will need to pick a temporary number and contact the CS_Agent to complete the porting of your old number.
  • Keep the old SIM in your phone and wait for the text from old carrier and confirm with YES you are porting over to PM within 90 minute window once you get the text.
  • Keep the old SIM in your phone until porting process is completed because the old SIM will continue to work for about 2 hours.
  • Power off the phone once porting is completed then switch to PM SIM and power on your phone.
  • You will need a Canadian CC or debit card to activate your SIM/Account.
If you are no porting your number and pick a new number. Just pick numbers that are available in step 5.
will13am
@Kar68 , this help article explains everything you need to know about how to subscribe to this service.
https://www.publicmobile.ca/en/get-help/articles?category=_articleCategory_getting-started
hairbag1
@Kar68
what do you need to know.
You need to download the Public Mobile app to your cell to activate a new account.
If you wanna use your old number, don't cancel the old account until after you successfully activated your new account and ported to Public.
What else do you wanna know ?
