Issues with cell tower
Jfour
All calls through this cell tower garble outgoing voices, doesnt matter what phone is used. All inbound voices loud and clear. Have two to three bar. No way to tell Telus because they cant hear me.
Timer
@Jfour
do you tried manually select network 3G only or WCDMA only. and rebooting device.
HI @Jfour   What kind of phone do you have?  make and model?
do you get better voice for outbound calls when you are at different places?
open ticket with PM CS Agent and let them confirm if any known issue with the towers around you area:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Meow
You can report this issue to agent. Maybe they are not aware of this issue.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
