Issues transferring number
JessSenft23
I am trying to transfer my husbands number to his public account. It is telling me his number isn’t a Canadian number and that we have to contact Koodo to transfer. He is currently with Sasktel and has a number from Lemberg Sask. has anyone had this issue before? How can it be resolved so that he can keep his old number
CSA_PM
Customer Support Agent
Hello @ JessSenft23,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
JessSenft23
Thank you. I’ve contacted them so hopefully get some assistance there!
@JessSenft23  You can buy public mobile SIM card from Telus or Koodo . But the link I sent you in my last reply  is for private message to support not the chat bot which I struggle to use myself . But if yours worked then I assume his should work too I would just want to verify with support and can’t say  with certainty that it will most cases most numbers can be ported to public but it all and  I would want to be 💯 certain first
JessSenft23
We both have Sasktel we are on one plan with them. Mine worked just fine. The support chat has not been helpful at all. Could he go into a Telus place and get a physical SIM card and transfer his number ?
@JessSenft23  Unfortunately not all number can be transferred to public mobile , and so if he’s with Sasktel there’s good chance it cannot be transferred to public mobile . Be best to confirm with support first or you might need to pick new number from public mobile instead
send  a  private message   To CS_Agent
