Issues regarding my ESim
Sukh2
DaveDelSole
I had problems activating esim, once I removed my old carriers sim card from the phone, all was well!
@Sukh2 did you port your number into PM?  or that is a new number you got? you able to make calls and data working
try to click Reset all networks and see if it helps
if not, message support:
@Sukh2  Remove your personal info this is a public forum
Add tap the arrow by the time stamp in your post and edit out your phone #
