05-21-2023
09:02 PM
05-22-2023
12:17 AM
computergeek541
I opened a Public Mobile account and transferred my accounts over. I have not had an issue transferring 3 of 4 accounts. The 4th account has had an issue. I have confirmed with the Telus porting number that both my Telus number has been transferred and that Public Mobile has successfully accepted it. I have confirmed that my SIM card number is correct but anytime I txt it fails and if I try and call the call immediately drops. The Telus/ Public Mobile rep let me know that everything is good on their back end and that I need to go online to msg a Public Mobile admin to have them correct something on the Public Mobile back end. PLEASE HELP
05-22-2023 09:24 AM
CS_Agent has resolved the issue on the back end everything is now working
05-21-2023 09:09 PM
Thank you @BKNS27 I have sent a msg to the CS_Agent fingers crossed for a quick fix!
05-21-2023 09:07 PM
It seems like you are doing it correctly for the first 3 porting but it looks like it is a provisional/backend issue with the SIM so contact a CS_Agent by typing in Submit a Ticket on SIMon Chatbot on the bottom of the page or private message on the envelope icon above.
I will pm the Porting Department number.
05-21-2023 09:04 PM - edited 05-21-2023 09:06 PM
@Buddytheguy wrote:I opened a Public Mobile account and transferred my accounts over. I have not had an issue transferring 3 of 4 accounts. The 4th account has had an issue. I have confirmed with the Telus porting number that both my Telus number has been transferred and that Public Mobile has successfully accepted it. I have confirmed that my SIM card number is correct but anytime I txt it fails and if I try and call the call immediately drops. The Telus/ Public Mobile rep let me know that everything is good on their back end and that I need to go online to msg a Public Mobile admin to have them correct something on the Public Mobile back end. PLEASE HELP
Add: before get help, first reboot the phone or try put sim card to another phone to see if it works or not.
There are 2 methods for help:
1. Chat with Simon for help, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
2, If have issue with Simon, send private message to CS_agent for help:
