Issues incoming call
Desraj
Incoming call can’t recive
@Desraj
What plan are you on? If $15 there is a version of this plan that only allowed 100 minutes of calling whether in or out. Your outgoing calls would stop as well if you have used your 100 minutes up but this could be the case and you are wondering why incoming stopped working as well.
For quicker more detailed responses, more info would be very helpful.
How long have you been a customer of PM
How long have you been on the plan you are currently on?
What does someone get when they call your number?
Does your phone ring when called?
Have different people / numbers / lines tried calling your number?
AE_Collector
gblackma
@Desraj if it isn't a new activation or you choose a new number. Then try these  tricks to reset your service. You could try in order:
1.Restarting your phone. Turn it off, remove the SIM card, reinsert it, wait 5 minutes and restart it.
2.Putting your phone on aeroplane mode for 5 minutes. Take it off and restart.
3.From your self service account enable the lost/ stolen feature log out, wait 5  minutes, log in and take it off. Log out and restart your phone. try these  tricks to reset your service.
 4.A network reset and restart your phone if it doesn't automatically do so.
If they fail contact the moderators and ask them to reset your service for you.  Stay safe.
gblackma
@Desraj if this is a new activation and you ported your number it takes up to 7 days for a voip or landline and up to 3 hours to complete for a cell phone number. If you ported from another cell provider and its been over 3 hours, your port is probably stuck. Contact the moderators and ask them to fix it for you.
There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
