01-05-2023 09:46 PM
I recently changed phones and now when I try to call the voice mail number it states that the number does not exist. Can anyone help?
01-07-2023 09:24 PM
True,
on Android
Open Phone app
click the options on the top right (3 dots) > Settings > Voicemail > Voicemail Number
Input 17785804001 ,or any VM number you choose
01-07-2023 09:15 PM
iphone or Android? That's the code for iphone.
01-07-2023 09:14 PM
@Macje which VM number you picked to use from the page I provided above? Try to manually dial that number and see if that works.
If it works, use the * dial sequence and enter it on your phone
01-07-2023 09:09 PM
I tried this and got the following error
01-05-2023 09:48 PM
@Macje Update the Voicemail number to one of the number on this post. Pick one in your province
Click the Phone icon.
Choose Keypad.
Input *5005*86*17785804001#.
Press Call to program the number.
"17785804001" can be replaced with any of the voicemail access numbers on the above link
