11-28-2022 02:59 PM
I was porting my number out of Public mobile last night, and I got all the way to replying "yes" to an SMS. My service got deactivated with Public but never activated on the new network. I'm in limbo without being able to do anything with my old number and porting is not going through. What can be done here?
11-28-2022 08:01 PM
Cancelled by Public it is
11-28-2022 08:00 PM
Now the issue is that on their side they see the request to port my number as cancelled and Public Mobile sees it as completed. I’m in a vicious circle
11-28-2022 07:48 PM
Hey! Thanks for the tips! The number is deactivated indeed, I’ve sent a message for support
11-28-2022 03:16 PM - edited 11-28-2022 03:16 PM
Confirm your account has been deactivated/closed by putting your PM sim in your phone and dialing 611.
If it has contact an agent :
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
11-28-2022 03:07 PM
They said it's some system glitch, and they're unable to bring in my old number. and that if they did anything, I'd need to have access to my old number. which is not possible at this point
11-28-2022 03:01 PM
So did you reply Yes? Once you port out your account is closed. What did your new carrier say? Is it a problem on their end?
